S7-1200 to CLX Conversion
Bullzi
Jun 2012
Colorado
1,530
Hi Everyone,
Looked at a job today where they want to change over several S7-1200 PLC Panels to run off of one 1756-L82E Processor.
I was wondering if there was a device that I could install in place of the S7-1200 processors that would let me use the installed S7 I/O Modules as a Remote I/O on a Ethernet/IP Network?
This would make the change over a little easier and less expensive. Thanks for any info you can provide!!
The S7-1200 can act as a Profinet-IO device, maybe there's a bridge from Profinet to Ethernet/IP.
But you need to replace the program of the 1200 to enable this function.
https://cache.automation.siemens.com/dnl/DE/DE3NjU5AAAA_108740380_Tools/108740380_TCPCommRA_lib_en.pdf I believe this is a useful link for people...
1,496
Hello, I have a question about an encoder that has absolute measurement. Specifically, it's the Lika SMA5, which I would like to connect...
54
31
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
268
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
96
