S7-1200 to Zebra Printer
Big_Robo
Nov 2016
England
81
Hi, I am having a right nightmare of a time. I have never programmed a Zebra printer before and need some help from you professionals. I don't want to make any mistakes. The Zebra is using RS232 into a Siemens S7-1200.
I have no idea if the Zebra needs a label layout then apply a script.
I have attached in the zip file with a picture (PICTURE 1) which the project currently produces and (PICTURE 2) which is what is wanted (adding of a Data Matrix). I have also added the project Tia V12 and apparently a script from a similar label.
Any help would be very much appreciated.
Hi everyone, Does anyone have a guide on how to communicate a zebra printer with a s7-1200 plc via TCP using TIA portal?? or any advices on what...
1,856
Hi, I need help about how establishment communication between a Siemens S7-1200 plc and a Zebra ZM-400 printer over Ethernet. I am using Tia V13...
2,706
Hi, I have an AB Micrologix 1200 connected with a Zebre TLP2844. Please I need help at printing barcode labels from a Micrologix 1200. I need...
6,645
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
257
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
82
