S7-1200 & tp177b
Mike_RH
Sep 2006
Toronto
896
Anybody have experience with this combination?
WinCCFlex 2008 is at SP2.
The TP will not reliably communicate to the CPU (S7-1214)
There is a duplicate station as a WinCCFlex RT and it works fine. It is only the TP177B that has a problem.
Sometimes it communicates, but mostly not.
Any suggestions appreciated.
I need to figure out a workaround using a siemens TP177B with a s7-1200 plc. I cannot use a basic kpt600pn because siemens is backlogged for...
5,333
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
256
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
82
Hi, I have attached herewith one image which our programmer has been used in S7 1500 PLC. Now we need to use the same instructions in S7 1200 PLC...
120
commentaire communiqué siemens s7-1200 avec vfd delta ? (cablage et sur tia portal )
136
