S7-1200 Upload Issues
theutinck
Aug 2014
Ontario
21
Hi all,
I have encountered this error when I tried to upload a project from a customers PLC.
"The program on the CPU is incompatible with the STEP 7 project. the version in the CPU:V0 --> the version of the STEP 7 project:V12"
I've tried to upload using Version 11 compatibility in V12, V12, V12 in compatibility in V13, and V13. the message is always the same.
thanks
Hey there.
Maybe of no use to you but I ran into this issue myself once. Turns out I had the right version of TIA portal. however, the PLC file had been done with Service Pack 1 and a full set of updates. Once I downloaded these updates and SP1 I was good to go.
solved
Ok I found the issue with the help of a Siemens tech. turns out that the original program was created in version 10.5. I talked to my rep and he will get me a copy of 10.5 software. I will upload and then convert to the various versions until its V13.
thanks
Hello members, I have Siemens S7-1200 PLC (CPU 1214C AC/DC/Rly version 3.0) and I want to get backup from it. I know how the procedure works. I...
139
I am new to siemens and I am trying to backup program from a S7-1200. Firstly I tried to connect using TIA Portal V16, then it shows the program...
2,132
We need to make upload from a Micrologix 1200 series C Bul. 1762. I have RS Logix 500 pro, but my knowledge of Rockwell is poor. How can I connect...
1,990
Dear sirs I have plc S7 1200 from Siemens loaded with file used tia v12 and i have tia v13 on my pc when I have tried to upload I can not upload...
4,014
Hi, I want to upload application from Panelview1200. Which software and communication Cable is required to upload application from Panelview...
2,248
