Hi all,
I'm using my 1500 PLC to communicate to two modbus slaves devices via RTU comms:
Comms settings being: 9600 8N1
Every now and then the modbus slave devices seems to hang up momentarily. The manufacturer states I should reduce my polling rate to 500ms to reduce the overhead on the slave device.
I'm using the standard Modbus_Com_Load block to parametrise the comms settings, but I don't see any poll rate adjustment in the DB?? Is this done somewhere else?
I carry out 3x read requests and 1x write request / slave. My code only sends the write pollss on exception.
Would adjusting the INCHAR_GAP parameter in the Modbus_Com_Load block give me the same effect as poll rate adjustment? It is by default set to 0ms, I have set it to 200ms and I can see the Tx Rx LEDs have slowed.
If anyone has any thoughts, Id be very grateful!!
Many thanks!
Many thanks!
