S7-1500 SCL, TIA V14 versus Classic
Pete.S.
Mar 2016
Fl
463
Hi guys!
Is there a document somewhere that states the difference between SCL in TIA portal versus SCL in classic Step7?
I want to reuse some code from old projects into the TIA portal but I get many hundreds of compile errors.
For instance this one:
Code:
   function XYZ : void
   var_temp
      z             : word;
      bit [B]at[/B] z : array [0..15] of bool;
   end_var
Generates the error "Data type AT construct is not allowed here."
But looking at the help file using "AT" is perfectly fine but not in the same places as before it seems.
Also
Code:
   function XYZ : void
   [B]const  [/B]
      b0 := 8;
      b1 := 9;
      b2 := 10;
   end_const
Generates the error "Unknown instruction" on const.
Isn't local constants allowed anymore inside functions?
Anyway, I searched the net for some kind of new versus old on SCL but came up with nothing. Any suggestions?
Thanks!
-Pete
PS. I'm using the function where you generate blocks from external source files.
How about this
I did it in the TIA editor, and it compiles ok.
FUNCTION "Block_1" : Void
{ S7_Optimized_Access := 'TRUE' }
VERSION : 0.1
VAR_TEMP
z : Word;
"AT ATz" : Array[0..15] of Bool;
END_VAR
VAR CONSTANT
b0 : Int := 8;
b1 : Int := 9;
b2 : Int := 10;
END_VAR
BEGIN
END_FUNCTION
How about this
VERSION : 0.1
VAR_TEMP
z : Word;
END_VAR
VAR CONSTANT
b0 : Int := 8;
b1 : Int := 9;
b2 : Int := 10;
END_VAR
BEGIN
END_FUNCTION
That's great Mike!
VAR CONSTANT looks like it's the replacement for const.
But the AT command hasn't the same function anymore. You just used it as a name.
The purpose of the AT is to overlay two different variables on top of each other. In my case I wanted to access bits in a word like an array or the word itself. Maybe there are other ways to do the same thing. By overlaying with AT, two types of variables occupy the same space. Most structured languages has support for this in one way or the other.
Hi guys!
Code:
   function XYZ : void
   var_temp
      z             : word;
   end_var
Also
Code:
   function XYZ : void
   [B]const  [/B]
      b0 := 8;
      b1 := 9;
      b2 := 10;
   end_const
Thanks!
-Pete
Here are some links that may be of some help:
Must read and includes links to the documents below
Document1
Dcoument2
Document3
Document4
Hi guys!
Code:
   function XYZ : void
   var_temp
      z             : word;
   end_var
Also
Code:
   function XYZ : void
   [B]const  [/B]
      b0 := 8;
      b1 := 9;
      b2 := 10;
   end_const
Thanks!
-Pete
Use the migration tool instead.
Hi guys. I have a challenge that I'm struggling with and I can't help thinking there's a really easy solution. I want to move a series of...
18
5,854
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
87
85
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
106
Hi all Trying to remotely connect to a TIA Portal PLC. I can ping it without a problem but can't get my software to connect. I've opened port...
336
