S7-1500F profinet FDBACK safety function
cottagewood
Oct 2005
Kent
179
Is it possible to use the feed back safety function with a drive over profi-safe and if so, what do I use for the input QBAD_FIO?
If I was doing this with a hard wired safety circuit I would have the STO output from the drive as a feedback signal into the safety relay.
When using a contactor on a failsafe output card, the FEEDBACK input would come from contactor and the QBAD_FIO signal would come from the process input word of the output card.
I have the STO status of the drive in profisafe to use as feedback but I can't figure out how to control the QBAD_FIO input.
Would an option be to use the ESTOP function and put the STO in series with the ACK signal?
Its n S120 drive and I'm using the Seimens LDrvSafe Library functions.
The STO is working fine, when I operate an estop or light guard I can see the STO is active.
When I restart I want to check STO is active as I would if I was using a hardwired safety relay
PLd
I'm trying to download a project for Siemens S7-1517F safety PLC to S7-PLCSIM Advanced 3.0 simulator and I'm getting incompatible firmware issue...
1,573
Has any one got any experience with Safe Limited Speed , I've used the standard library functions for the drive safety and standard telegrams...
2,217
Hello all, I am planning an application where I have a cluster of conveyor belts (~20) where each on has its own local E-stop. I want to use an...
2,645
Hi I need a safety system with safety encoders as input (profisafe bus) and digital outputs. When position or speed of some rotating device...
1,736
161
