S7-200 Conversation, * and & prefix
Paullys50
Jan 2006
WI
2,188
Hey guys, doing a small program conversion of an old system. The existing system uses an S7-200 PLC, logic is pretty straight forward however there are some block moves going on that I 90% understand but when I see * or & as a prefix, I don't know what that means.
Example:
| BLKMOV_B |
*#Temp_5| | VB3370
30 | |
It appears 30 bytes of data are moving from the *Temp_5 reference, starting at VB3370 - VB3399.
I am trying to understand where the source data is coming from. Temp_5 appears to be the result of a calculating a starting reference point for the block move, but does the * indicate something else?
There is another area that uses &VB3520, what does '&' mean?
Thanks! Flipping through the manual in the mean time.
Hello, I have a question about an encoder that has absolute measurement. Specifically, it's the Lika SMA5, which I would like to connect...
54
31
Hi. I have a 222 CPU. I need to recover the program from the eeprom memory. Is it possible?
105
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
268
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
96
