S7-200 Pgm Cable Self Made
Ramsri
Apr 2014
coimbatore
40
Fellas,
I want to Program the S7-200 PLC with Rs485 to USB converter without using Siemens PC/PPI cable since the cable which i had was failed recently. For this I have soldered 3
(D+), 8(D-) RS485 Pins in PLC side and converted this as USB With the Converter to my PC. I have selected the PC/PPI in the S/W settings & the Software was trying to read the PLC with all the baud rates. but PLC is not detected?
Any one had Success of Programming the S7-200 PLC without S7-200 Siemens Cable?
Hello, I have a question about an encoder that has absolute measurement. Specifically, it's the Lika SMA5, which I would like to connect...
56
34
Hi. I have a 222 CPU. I need to recover the program from the eeprom memory. Is it possible?
110
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
273
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
98
