S7 200 WinCC connections??!!
Tarek_Ashraf
Mar 2009
cairo
Hello,
I’m a student and in my project I’m using a PLC S7 200 CPU 222 connected to WinCC flexible 2005 SCADA system via RS232 PC/PPI cable and USB/serial converter…and attached my communication settings for both WinCC and Micro/Win….and I have configured the dip switches of the cable so that switches 2 and 5 are set to 1….(2 for baud rate of 9600 bytes and 5 for PPI(M Master))…so I have made a sample project just to check the connections….downloading the ladder to the PLC was successful but whenever I try to transfer the project from WinCC an error appears (check your settings, interfaces, cables,….) so could you please help me to find what’s wrong with my settings….
Thanks….
I see in the pictures you're mixing MPI and PPI settings. MPI is 187500 baud, PPI can be used at baudrates between 300 and 38400. Make sure you're only selecting PPI in all screens.
Kind regards,
thanks for replying Mr Jean but unfortunately in the WinCC transfer settings i cant find PPI settings there's only serial,USB,MPI/DP and ethernet....and by the way i've tried all of these connections and the same error appears...should i change the panel or something? if not what else could be the problem?
You are mixing apples and pears.. The transfer function in wincc flex is for transfering your HMI project to panels or another PC.. You don't need to do it to connect to PLC.. Just try running the project. Then see if you have connection.
that depends on the type of connection PPI,MPI,DP,ETHERNET or A MODEM....specify its type and use them in the transfer settings in wincc and ask for more details..
Hello all, I am trying to connect an existing Siemens WinCC SCADA to a new machines S7-1200 PLC. I have connected anpther 1200 and a 1500...
2,905
Hello everyone, I have 8xS71200 cpu fitted profinet with Wincc RT on pc station .I use tia portla v13 sp1 and i want to check and show current...
9,590
Hey folks... I've been thrown into the deep end of a dodgy pool. A life line would be appreciated. Our one and only resident PCS7 knowledgable...
4,059
Hi! I need to sync the time of my WinCC Flexible 2008 RT with my s7-1200. How on Earth do I do that? I can't find anything helpful on Siemens...
3,007
Hi all, i am using s7-1200 (CPU 1214 DC/DC/DC) & wincc runtime SCADA v12(professional)[General PC] & this kind of project , I am handling for...
3,751
