s7-200 & WinCC
bhavik
Sep 2003
india
28
hi, i m doing project on siemens s7-200 (cpu-212).micro/win, the programing software currently communicating with PC/PPI cable.
for SCADA, i m using WinCC(version-4.01) which i programmed for pc adapter(MPI).WinCC do not support PC/PPI protocol.
now,plc can be programmed for MPI.so, what hardware i require so that SCADA also communicate.
also, plz. explain me how it will work.also some related links if possible.
thanx......
WIN CC supports OPC. So you can set up an OPC connection to the S7-200 via PPI.
Siemens OPC server for PPI: SIMATIC MicroComputing 6ES7810-2MS00-0YX0 (only ONE PPI connection !).
For 3rd parties: There are LOTS of hits of you try "PPI OPC server" on google !
Hello all, I am trying to connect an existing Siemens WinCC SCADA to a new machines S7-1200 PLC. I have connected anpther 1200 and a 1500...
2,878
Hello everyone, I have 8xS71200 cpu fitted profinet with Wincc RT on pc station .I use tia portla v13 sp1 and i want to check and show current...
9,563
Hey folks... I've been thrown into the deep end of a dodgy pool. A life line would be appreciated. Our one and only resident PCS7 knowledgable...
4,054
Hi! I need to sync the time of my WinCC Flexible 2008 RT with my s7-1200. How on Earth do I do that? I can't find anything helpful on Siemens...
3,004
Hi all, i am using s7-1200 (CPU 1214 DC/DC/DC) & wincc runtime SCADA v12(professional)[General PC] & this kind of project , I am handling for...
3,739
