S7-200
Ken J
Feb 2005
Mentor, Ohio
82
Does anyone know if there is a way to search a particular coil address for all locations of it's contacts in the program?
RS Logix 500 allows for searches by coil or contact address by listing consecutively each occurrence.
I think this is what you're asking Ken. You have to do a full compile before you can get a updated cross reference though.....Hope this helps. There is a bit missing off the image(to the right) showing coil and contact designations - seems you can only attach an image 550 wide??
alternatively, you can press "CTRL" + "F"
and type what you are searching for, in this case you wont have to compile the programs.
I use this to do searching when my program is not in a situation, to be compiled ;)
Hello, I have a question about an encoder that has absolute measurement. Specifically, it's the Lika SMA5, which I would like to connect...
61
37
Hi. I have a 222 CPU. I need to recover the program from the eeprom memory. Is it possible?
141
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
288
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
107
