s7-200
DIMPOL
Oct 2002
24
LD MW10>=11
R M10.O, 3
This command will reset the bits M10.0, M10.1, M10.2 and M10.3 when MW10 = 11 (s7-200) ?
No, it will reset 3 bits starting at M10.0. Thus only bits M10.0, M10.1 and M10.2 will be reset. M10.3 will remain.
Kind regards,
Thanks for answering. I will make one more question. If i want to multiply 3276 with the content of VD7, the content of VD7 can be changed from four inputs which controlled by me, How can i get the result of the multiply constantly?
Hello, I have a question about an encoder that has absolute measurement. Specifically, it's the Lika SMA5, which I would like to connect...
58
35
Hi. I have a 222 CPU. I need to recover the program from the eeprom memory. Is it possible?
125
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
286
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
100
