s7-200
aladawi1
Oct 2007
jordan
Hello:
I am working in steel structure factory, and we have wagner drilling with sematic
s7- 300 control system .actualy we have some problems in our machine .
On my PC i have s7-200 software , can i join the the s7-300 to PC with s7-200
software and how i can do it.(the connection i am using to CPU is MPI.
with best regards
S7-200 and S7-300/400 are two completely different types of PLCs. The software package for S7-200 is called Step7 MicroWIN, for S7-300 and -400 you need STEP7 or STEP7 Professional.
The answer is plain and simple: no, you can't use your software with S7-300.
Kind regards,
Hello, I have a question about an encoder that has absolute measurement. Specifically, it's the Lika SMA5, which I would like to connect...
38
25
Hi. I have a 222 CPU. I need to recover the program from the eeprom memory. Is it possible?
99
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
260
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
83
