s7 200
Nelliyan
Sep 2011
90
Now i configured my s7 200..... in my program i have to get some signals from another plc.. so can u tell how to perform the profibus communication between the plc's.... i found it for 300 but cant in 200 .... so pl guide me
An S7-200 can only be used a Profibus Slave, It can not be used as a Profibus Mater. You can use PPI or Modbus to talk between 2 S7-200
hi ,
For analog program u need "SCALE" library
c the attached library file & Use itr function.
Regards,
Nelliyan.G
Profibus slave only by using a em277 module not by local ports
but right, s7-200 to s7-200 comm is only thru PPI Siemens Protocol or building a modbus RTU Master slave small network...
Or maybe by adding an expensive ethernet module on each but it is probably better cost efficient to discard s7-200 and use newer s71200 in this case with the built in ethernet port...
Hello, I have a question about an encoder that has absolute measurement. Specifically, it's the Lika SMA5, which I would like to connect...
59
35
Hi. I have a 222 CPU. I need to recover the program from the eeprom memory. Is it possible?
127
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
286
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
103
