manmeetvirdi
Hi there LD
Dint understood what you meant !
Anything wrong in here. I tested code, it works.
Testing FB operation as multiple instance means what?
Does it means calling FB along with other FB's and and FC's?
"Make sure it is not the first entry in the STAT section."
Here "it" refers to what? Anything to do with AR2? I mean when FB is called AR2 points to first entry of the DI, right??? that is DIX0.0
But then you make it point to some other location, right?
coding hardway means what?Why have you hard coded the DI number ?
Actually I just called the FB2 from OB1 for testing.When using indirect addressing in FB's, always test the FB's operation as a multiple instance making sure it is not the first entry in the STAT section
