S7 300 And Software Redundancy
sanjay_snj
Jan 2004
ABU DHABI
36
hi guys !
i have 2 nos 315-2DP cpu configured in software redundant way using IM153-2. there was 2 profibus dp and both connected to stations. actually when i see the project, i find the following icons on the right side - (a) CPUA (b) CPUB (c) MPI(1) (d)PROFIBUSA (e)PROFIBUSB
I did some changes in the programming as per my process requirement. i did not do any hardware changes. during loading the new blocks, some problem came and i downloaded the complete config. including the hardware and system blocks also.
after that i found some unique changes. now when i was going online and stopping one cpu, it was not reflecting in the laptop. only after stopping both cpu, it was reflecting.
but when i stop one cpu, the 2nd cpu still takes over the plant does not disturb.
when i see the projecy, now i see the following icons - (a) CPUA (b) CPUB (c) MPI(1) (d) MPI(2) (e)PROFIBUSA
i do not understand what happens. actually i want to normalise the hardware configuration as the previous one as i did not change the hardware physically.
i know there is one way to copy the new software blocks to the old project and then download the complete config.
but is there any other way. can anyone tell me how to copy only the hadrware config. from the old project to the new project, keeping the same software and download it to cpu ?
pl. help
Hello! I haven't worked with software redundancy before, so I was wondering if I could use the CP343-1 Lean modules (which I'm using for the...
1,772
Dear Experts, I am working on a system with S7-300 software redundancy due to high availability requirements of the control logic. My question...
2,116
Anbody ever used S7300 with the software redundancy blocks FC100, FB101 etc? I am told that the declaration of IEC timers and associated DB's...
4,055
Hey Ladies and Gents, I'm new to PLCS.net and have a problem with working with the software redundancy of Siemens. What I have: 2 - 315-2...
18,267
Hi All, I am using S7-300 CPU-317-2DP with IM 153-2 for Software Redundancy. I am using Ethernet as Redundant Link. When the Master PLC is...
6,622
