S7-300 Communication issue
bill4261
Jan 2005
mid-west
99
I have a S7-318 and 224XP with a profibus module. I can not communicate between the two of them. I have the hardware setup in the S7-318 as node 5 and the the I address is 400...415 and Q address 300...315(8 word out/8 word in) The V memory offset is 200. In the 224 the word that I am trying to see the the 318 is vd200. I've checked the profibus node on the module. I can see the vaule changing in the 224. I can not see the value in the hardware monitor/modify window. I'm thinking that i'm doing something wrong with the V memory offset or the address setup in the hardware configuration of the 318.
Thanks in advance for any help.
S7-200 on PROFIBUS
Do you have communication between S7-300 and S7-200? You can check this going online in hardware configuration of 318 or checking if 318 or EM253 has a red BF (Bus Fail) led.
Kelkoon
I don't have a 253 module. I have 277 profibus module on the S7-200. I figured out my problem. The offset was wrong as I suspected.
Hello everyone! I'm currently working on a project which requires communication between an S7-319 PLC (programed in TIA Portal V14) and an x20...
1,875
I'm having an issue getting explicit messaging to work between a micrologix 1400 and Kinetix 300. IP addresses and subnets are set up and I can...
2,000
gents, I am trying to configure communication with EMERSON PK300 controller through port A1 using generic ethernet communication module . I could...
116
Hello everyone, One of our machine we use Siemens Cpu315-2dp. And this cpu communicate with 4 Lenze servo drives series 9300 via profibus. Also...
185
Hi! I'm trying to communicate with an old Kinetix 300 drive that is fully functioning. Is there any library I can use to monitor this drive with...
433
