s7-300 communication problem
md.abdullah
Sep 2011
motihari
168
hello dear experts
i have problem in the communication of the s7-300 cpu
i am using usb mpi cable.i just want to upload pg station but failed to communicate.please tell netpro setting.
As i choose to display the access node then there is not not any access node .
how can i make sure any node while mpi all LEDS are green.
also i have cpu of order number 313-5bf03-0ab0,what is software revision for this type of cpu.
The only thing I can think of, is that you should use standard settings for PC Adapter USB. That means baudrate=187.5k, and node=0.
Your PC Adapter USB works with other CPUs ?
thank u for replying
but i am still in trouble
its not displaying any accessible node
i just want to know how can i get to disply a node
please help me
friend pc adapter part is
6Es79720cb200xa0
i have tried hard today but did not get any accesible node
can any one help me the setting for this?
The way i work around this is to set in the PC/PG menu the commmunication speed for mpi and try to upload plc hardware in step 7
it open a screen that permit to browse and see node adress...
If not working, i try it again with a different speed
start with 187k it usualy work first..
You may also be running a special bloc in the cpu that use the local port for another protocol that prenvent you connecting to it ? Is the port was connected to something like an HMI ? you could find HMI setting and put the same in your laptop PC/PG
Try setting PG/PC interface to both MPI and AUTO.
I've found in the past that sometimes MPI doesn't work but AUTO does?? (and vica versa??)
Worth a shot... ;-)
PS. Also try reinstalling the drivers for your USB adaptor and/or try a different USB port.
You can check in Devices/System to see that the USB adaptor is showing up under USB devices.
Hello everyone, One of our machine we use Siemens Cpu315-2dp. And this cpu communicate with 4 Lenze servo drives series 9300 via profibus. Also...
195
Hi, I am trying to communicate Panel view 300 with Micrologix1500 LRP. PLC: Allen Bradley Micrologix1500 LRP HMI: Panel view 300 CAT#...
1,985
i have a panel view 300 whos cat no. is 2711-k3a5l1 i am using comm'' cable 2711-nc13(rs232)cable when i connect it to pc and pv 300 after that i...
7,863
Hi, i have a machine with s7-300 and hmi panel connected by MPI. i tried to upload program from plc. i have pg3 and original mpi cabel from...
1,796
Dear Messes, Please forgive me if I had post in worng location and just deleted it. I had a problem in config the Siemens Sirec D300...
1,710
