S7 300 communication via cp343-1 lean
haithm
Feb 2021
cairo
I can not see the CPU s7-300 i only see the cp343 as photo the interface is through tcp/ip how can I upload the station via the cp343 module ???
I forget photo , sorry
is it possible to upload the cpu program via cp343 module ?? As I can see cp343 online but the cpu 313c do not appear online
How can I do that ???
You select Upload Station to PG.
You will get the dialog that you have posted.
Be sure to select Slot=2 instead of Slot=0.
You should now be able to upload.
Hi guys, i am sorry to asking you this question. To day i was trying to go line to s7 300 plc via ethernet but i am failure.At first i put...
2,708
Hi, I am looking to link 2 S7-300 plc's via profibus. Both PLC's already have profibus set up for communication of HMI's, Motor inverters, remote...
3,029
gents, I am trying to configure communication with EMERSON PK300 controller through port A1 using generic ethernet communication module . I could...
99
Hello everyone, One of our machine we use Siemens Cpu315-2dp. And this cpu communicate with 4 Lenze servo drives series 9300 via profibus. Also...
181
Hi! I'm trying to communicate with an old Kinetix 300 drive that is fully functioning. Is there any library I can use to monitor this drive with...
426
