I need to connect two systems (now independent) for data acquisition purposes via Wincc v7.0 software. One system (CPU-315 DP) is already connected with the PC via CP5611 processor.
Now I need to integrate the CPU-317 DP to the existing PC. My opinion is maybe go with the network cable solution and buy the communication processor for CPU317 DP for connecting to ethernet. Do i need only ETHERNET CP for the PLC or I need something for the PC? I have been looking at [FONT="]6GK7343-1CX10-0XE0 [/FONT],is this good enough for connecting the CPU on the PC via unmanaged PC switch?
This solution seems good for me because I would not need to make changes to existing program, and because of the new comfort panels from Siemens it is easier to make software in TIA portal, as the older system is made in Simatic Manager.
I did not had experience in Wincc7.0 so every help I can get is good.
Thank you!
[FONT="][/FONT]
Thank you!
[FONT="][/FONT]
