S7 300 Configuration
silviu_r
Dec 2008
Bucharest
I need your help regarding a master PLC configuration.
System: 12 VIPA CPU 214DP(CPU with MPI and Profibus DP slave interface) that can work independently. Each CPU communicate over MPI with an Siemens OP73.
This 12 CPUs and 2 IO DP stations have to communicate with one master S7 300 PLC over Profibus DP.
The master PLC communicate also with one PC were I have installed WinCC Flexible application and an OPC server.
For this system I want to use teleservice acces.
Please help me with a solution for: master CPU communitation interfaces(315 is ok for me), OPC server, and TS adapter to use.
Cheers!
You can use a any Siemens/Vipa master CPU.
Why you need OPC server if you connect WinCC flexible with Siemens/VIPA CPU?
You can use TS adapters from Siemens, VIPA or other manufacturer conected to MPI(I am not sure if it is possible to conect a TS adapter to profibus on VIPA CPU's).
If you need help with HW configuration of the project send me email and I will send you a example project(it's 400kB and not possible to attach here).
Regards,
Mitko
I use OPC server to send informations to another system (ICONICS). This OPC server it will be installed in the same PC with WinCC Flexible (or maybe i can use the OPC server from WinCC flex).
I need a cost effective sollution.
My sollution is the next one:
- CPU 315 2PN/DP (MPI for teleservice, ETHERNET for PC with WinCC Flexible)
- CP 342-5 for Profibus communication with 12 CPU 214DP and 2 DP stations.
My concern: I don't know if the OPC server from WinCC flexible is satisfactoy for my client, so i want to have an alternative. If I will install an OPC server(ex:SIMATIC NET IE SOFTNET-S7 LEAN/ 2007) on the same PC with WinCC flexible how can I connect the ICONICS to this OPC server(i heard from a guy that is a problem with 2 ethernet connections):confused:?
Best regard,
Silviu
Sorry,
but I am not a SCADA specialist, if you have a questions for the PLC, I will try to help.
For the PLC configuration I will recomend(because of price and easy to configurate) to USE CPU 315-2DP(MPI for teleservice,Profibus for VIPA)
and CP 343-1 LEAN for the WinCC Flexible. its almost 600 euro cheaper.
Regards,
Mitko
Hi i using Kinetik 300 2097 driver control by EIP with using move absolute and incremental for motion , but i want to add same driver and motor as...
55
I have Windows 7 Pro and am trying to configure ABs 9300-USBS USB to RS232 adapter. I have done it in Windows XP but am having problems with Win 7...
2,294
Hi, I got two questios: There are two slave devices(SEL-787) from which I should read data via MODBUS RTU. I checked SEL-787 manual and it says...
5,556
Is there a way to configure these starters without the faceplate? The customer did not buy any faceplates and the manual refers to different...
2,150
Hi , I am looking for the solution, how to configure I/O of E300 . For example , Input 1 trigger Output 1, Input 2 trigger Output 2. In...
1,294
