S7 300 connected to old S5 I/O
rigicon
Aug 2009
kent
415
This is one for the siemens crowd.
We want to replace a S5 95U connected to 3 banks of I/O I am not kidding when I say lots of I/O. All I/O are 8 bit digital input or output. Banks are approx 1.5m long.
Ideally we don't want to rewire the whole panel with new I/O.
It would be nice having a S7 300 take the place of the S5 95U.
The program in the 95U is a simple cell controller all in ladder so not worried about the program conversion.
Not sure if it is possible to use the old I/O ? o_O
I wrote a small note about it in the downloads section.
But the bottom line is: Apart from interim solutions where the proces has to run close to 24/7, it is not worth the effort or the expense.
In 99% of the cases, the smartest is to ditch all the S5 stuff in one go.
A 313C CPU is the closest match to the 95U CPU, with the same or more i/o onboard.
Personally I would go for a an IM151-8 CPU + ET200S i/o. That gives you the most flexible i/o + ethernet at the lowest possible price.
A small detail why ET200S may be the smarterest solution:
S5-100U i/o, which the 95U also use, have the terminals low down and at the back at the mounting plate. That means there is a risk that there is not enough extra wirelength.
If S7-300 i/o is used, the terminals are higher up and away from the mounting plate, maybe too far away for the existing wires to be reused.
If ET200S i/o is used, the terminals will be very close to where the 100U terminals used to be.
Thanks JesperMP good honest answer.
I was hoping to use the S7 300 to profibus to a new mould but looks like it will be the old hard wire way. The company (commercial manager) can't understand why we have to do away with working kit and replace with new working kit. Commercial managers are a engineer's worst enemy. I am red in the face explaining but they don't see it !!!
By the way, like you suggest yourself, another option would be to hook up the old i/o to an existing PLC via Profibus.
Again ET200S is cheapest, most flexible.
Dear Friends; We have a BOBST 1228 flexo printing machine having Siemens S7-300 PLC (6ES7 318-3EL01-0AB0) and Lenze 9300 and 9400 drives. The...
2,317
hi there its my firest time working with profibus and i have already install gsd and networked profibus in step7 hw config and inserted base...
2,515
Error 612 no active nodes found on network. I'm using an Allen Bradley 1761-CBL-PM02 SER C cable. I downloaded the program to the PLC and to the...
4,636
Replacement of variator Danfoss "VLT 5000" "FC 300"connected to S7 300 "PROFIBUS" Hello, I must replace the variator VLT 5000 by FC 300...
3,389
replacement of a variator "VLT 5000" by another "FC 300"connected to PLC S7 300 "PROF Hello, I must replace the variator VLT 5000 by FC 300...
2,778
