replacement of a variator "VLT 5000" by another "FC 300"connected to PLC S7 300 "PROF
sharo
Mar 2009
Casablanca
Hello,
I must replace the variator VLT 5000 by FC 300.
please, which are the change which I must make?
1.I installed the file GSD which corresponds to this new 2.variator,
3.I replace VLT5000 by FC300 in hardware configuration
4.I change a adresses of FC300 to the same adresses of VLT 5000
5.I use in FC300 the same PPO type used in VLT 5000
it is sufficient?o_O
if not, pleaaaaase, what do I have to make?
should be enough..with the same PPO is ok.
Maybe some special hardware wire connections on the new device..
Greets:
V.
In Danfoss, there is an interface, it can automatically replace VLT5000 by FC 300 but it's expensive.
I want to do this replacement without buying this interface.
Replacement of variator Danfoss "VLT 5000" "FC 300"connected to S7 300 "PROFIBUS" Hello, I must replace the variator VLT 5000 by FC 300...
3,390
Hi , Where i can find Mitsubishi PLC Card end of line & replacement model details. i am looking for Q02CPU replacement model. Please advice. thanks
128
Hi , I am trying to replace an old inverter with a new one and its giving me issues . Once the new one was installed , the S7-300 PLC started...
131
Hi Everyone, I replaced encoder 842D-60131331BXA with a new same part number. Dip switches and Preset Push button are considered. When I tested...
234
Hello, I am kinda new to automation, I had an issue with 1743-EPAC which supply's 13 IO , when we inspected it there was a short circuit...
149
