s7-300 cup stopped
jugenzhu1963
Jun 2006
toronto
72
Hi
I have a 317T-2dp CUP WITH CP343-1 Lean. it was working good. i see some blocks are different between the online and the offline via compare block.so i want to update the offline block in order to monitor the block. but for some reason i can't do that. when i do an upload from plc it will never finished and showing "not responed". I think it may be because the communication setup problem. so i download the netpro by select download to current project.the download was not completed successfully. because it never finished and also showing "not responed".Now the cup is in stop condition. How can i fix this problem. i use the ethernet interface to comm with plc. i can ping the plc. but when i try connect with plc it said can't establish the connection. Thanks for any help.
in allen bradley kinetix 300 drive first E31 error shows after resting drive E11 error occurs need solution to reset E11 fault code
115
263
Hi i using Kinetik 300 2097 driver control by EIP with using move absolute and incremental for motion , but i want to add same driver and motor as...
64
Hey all, first time poster here. I am wondering if anyone has tried using a Keyence SR-X300 barcode scanner to a Micrologix 1400. Keyence sent...
66
