Hi all,
I am working on a project where I am needing to apply recipe data to some analog outputs based on a fixture number. I have a DB with 30 fixture recipes starting at DB720.DBB0 (structures made up of a fixture name (array of 1-12 chars), new/old boolean (new =1) and 9 real numbers). The length of each fixture recipe is 50 bytes.
I need to search through the fixture numbers and compare that to the fixture number that was transmitted by an upstream machine (another array of chars 1-12) starting at DB702.DBB10.
When I find a match, I need to copy the recipe data from the database (DB720) to the work area (DB710.DBB0).
I am new to STL and Siemens, but have many years with ladder. After doing alot of research, I found how to make variable pointers that I can increment. However, my code doesn't seem to work correctly. I am getting an "area length error when reading" in the processor and my sort doesn't seem to work correctly. Can anyone assist?
I have an "Any" pointer called fixt_mov_loc defined in the temp area at 0.0
Network 50
// WHEN NEW PARTS LOADED, LATCH THAT STATUS UNTIL FIXTURE SEARCH IS COMPLETE
A "0_DEG_PART_LOADING_OK"
FP "0_DEG_PART_LOADED_PULS"
S "0_DEG_PART_LOADED_LTCH" //LATCH SIDE A LOADED STATUS
A "180_DEG_PART_LOADING_OK"
FP "180_DEG_PART_LOADED_PULS"
S "180_DEG_PART_LOADED_LTCH" //LATCH SIDE B LOADED STATUS
A "0_DEG_FIXT_FOUND"
FP "0_DEG_FIXT_FND_PLS"
R "0_DEG_PART_LOADED_LTCH" //CLEAR SIDE A LOADED STATUS
A "180_DEG_FIXT_FOUND"
FP "180_DEG_FIXT_FND_PLS"
R "180_DEG_PART_LOADED_LTCH" //CLEAR SIDE B LOADED STATUS
Network 51
// SEARCH FOR A (0 DEG) FIXTURE PARAMETERS IN DB ARRAY
// START AT POSITION 1 AND SEARCH TO 30
//SEARCH THROUGH ARRAYS TO FIND FIXTURE
A "0_DEG_PART_LOADED_LTCH"
FP "0_DEG_PART_LOADED_PULS2"
L L#0
T "FIXT_PRES_POINTER_A" //INITIALAZE INDEX VARIABLE
NFND: A "0_DEG_PART_LOADED_LTCH"
OPN "FIXT_PRESS_DATABASE" //OPEN FIXTURE DATABASE DATA BLOCK
L P#DBX 0.0 //LOAD POINTER WITH FIRST FIXTURE NUM LOCATION
LAR1 //LOAD ADDRESS REGISTER WITH START OF ARRAY
L "FIXT_PRES_POINTER_A" //'INDEX' IS INCREMENTED BY 50 AFTER EVERY UNSUCCESSFUL SEARCH
SLD 3 //CONVERT INDEX TO POINTER FORMAT
+AR1 //ADD INDEX TO POINTER START POINT
L DBD [AR1,P#0.0] //POINT CHARS 1-4
T DB721.DBD 0 //XFER CHARS 1-4
L DBD [AR1,P#4.0] //POINT AT CHARS 5-8
T DB721.DBD 4 //XFER CHARS 5-8
L DBD [AR1,P#8.0] //POINT AT CHARS 9-12
T DB721.DBD 8 //XFER CHARS 9-12
L DB721.DBD 0 //LOAD COMPARISON CHARS 1-4
L DB702.DBD 10 //LOAD PARI FIXT A CHARS 1-4
==D //COMPARE CHARACTERS 1 TO 4 OF A FIXTURE NUM
A(
L DB721.DBD 4 //LOAD COMPARISON CHARS 5-8
L DB702.DBD 14 //LOAD PARI FIXT A CHARS 5-8
==D //COMPARE CHARACTERS 5-8 OF FIXTURE NUM
A(
L DB721.DBD 8 //LOAD COMPARISON CHARS 9-12
L DB702.DBD 18 //LOAD PARI FIXT A CHARS 9-12
==D //COMPARE CHARACTERS 9-12 OF FIXTURE NUM
JC AFND //IF ALL 12 CHARACTERS MATCH, JUMP TO CONTINUE PROCESSING
//ALL 12 CHARACTERS DID NOT MATCH, INDEX POINTER BY 50 AND COMPARE NEXT PART NUM
L L#1450
>=D //IF POINTER IS >= 1450 THEN AT END OF FIXTURE LIST
JC FALT //JUMP TO FIXTURE FAULT LOGIC
L "FIXT_PRES_POINTER_A" //LOAD POINTER TO ACC1
+ L#50 //ADD +50 (DOUBLE INT) TO POINTER TO INDEX TO NEXT FIXT NUM
T "FIXT_PRES_POINTER_A" // STORE INDEXED POINTER
JU NFND //LOOP TO SEARCH AGAIN
Network 52
AFND: A "0_DEG_PART_LOADED_LTCH"
L W#16#1002 // S7 pointer constant 10hex; Data type 02hex (= Byte)
T LW 0 // --> Byte 0 & 1 of ANY Pointer
L 50 //Length of data to be transfered in BYTES
T LW 2 // --> Byte2 &3 of ANY Pointer
L 720 // Set DB number to 0 (not applicable as Q are is used)
T LW 4 // --> Byte4 &5 of ANY Pointer
L "FIXT_PRES_POINTER_A" // Set Byte Number of Starting Byte
SLD 3 // Shift INT to make a pointer
OD DW#16#84000000 // Combine DB area and pointer
T LD 6 // --> Byte6 -9 of ANY Pointer
CALL "BLKMOV" // Copy 50 Bytes
SRCBLK :=#FIXT_MOV_LOC // Pointer to fixture found A in list
RET_VAL:="BLKMOV_ERROR" // Block move error
DSTBLK :=P#DB710.DBX0.0 BYTE 50 // Fixture A Pressure Location
= "0_DEG_FIXT_FOUND"
Network 50
Network 51
L L#0
A(
A(
L L#1450
Network 52
