s7-300 Factory Reset
Boxy
Nov 2008
Sydney
57
Hi, I am setting up a s7-315f-2 pn/dp CPU with ET 200M Remote I/O
I have had it up and running then without considering the maximum transmission rate of my PC/PG Interface set the Rate to 3Mbps. The computer froze up during this process and i had to restart. Is there a way reset the Profibus back to MPI or at least change the rate back down to no more than 1.5Mbps?
The common msgs are "Online: BUS Faulty" the error msg about the node is to high, transmission rate or interrupts are wrong
Any suggestions?
If other people look at this.
I was able to get in via the IE port and change the HW config that way allowing myself access to the DP port once again
Hi Any one here please helpmein simulation of s7 300 plc program with factory io. how to connect. plcsim 5 doesnot have option of s7 300 ..:
1,014
50
Hi i using Kinetik 300 2097 driver control by EIP with using move absolute and incremental for motion , but i want to add same driver and motor as...
53
45
Hi Siemens guys! I am experiencing SF fault on our S7-300 (6ES7 315-2AH14-0AB0) CPU from time to time. I've checked the diagnostic buffer and...
183
