S7-300 Interface Module Hardware Configuration
mobile1056
Sep 2005
North Central Illinois
This is my first time using Siemens S7-300 PLC's and in this project I will be using a IM360 interface module to connect to 2 other racks using IM361 interface modules in both racks. I am curious as how the 2 slave racks can be shown in the hardware configuartion of Simatic Manger or if there is another way this is done. We never covered this stuff in the Siemens training.
When starting with the hardware configuration you need to add a rack. On this rack you can add all the I/O/PLC modules. When the first rack is full you need more racks, with are connected using interface modules. In your case you need to add two more racks. You place the IM360 on the first rack (I believe on position number two but I'm not exactly sure, anyway it will only fit on one position).
On the other two racks you add the IM360 (also on 1 fixed position). You will see lines appear between the interface modules indication the connection.
There is no need for any settings or other stuff like addresses etc.
G
Dear All, I used Simaticn s7-300 CPU 314 (6ES7 314-1AF10-0AB0) Also I brough device SIMATIC S7-300. INTERFACE MODULE(6ES7 365-0Ba01-0AA0)...
3,456
Hi, I am updating an FB (S7-300 using V5.5), I added positive edge and added a stat variable to local interface, upload, I receive an "area length...
1,781
Hi, I'm new to Siemens and having issues connecting to a S7-315 CPU over ethernet. I can ping it, I can see it in my TIA V12 portal, but mt S7...
24
11,453
Hey all, I'm looking for a solution to interface a couple of S7-300's to an ethernet network so we can collect some data. We will be using...
1,496
hi, i was called in to help one of our customers with their PLC. it is a siemens which i'm not very familiar with. i typically work with GE...
6,116
