S7300-Ethernet interface
router
Hello,
Depending on the environment and application, you could use a simple router, maybe even a switch. But of course, if you need something more robust with more features for automation purposes, there are quite a few options out there.
But, I have only been told about solutions. Never played with them myself.
May I suggest VIPA teleservice modules which add some functionality to your setup.
http://www.vipa-usa.com/products/accessories/teleservice/
http://www.vipa-usa.com/uploads/tx_sbdownloader/DB_Teleservice_04_2010_ENG_web_01.pdf
Afternoon all, I've been well and truley dumped in the smelly (what's new?), I've hit a wall without even starting really and am hoping one of...
1,542
Hey all, I’m kind of spinning my wheels a bit with this one. I need to exchange data between to S7-315 PN/DP’s . I need to send a couple of Bytes...
1,481
I have an existing system design that requires ethernet functionality. I am using a cpu315-2dp with a profibus network that covers approx 100m...
2,085
Hi I want to ask several questions. 1- Is it possible to make communication between two s7300 plc via ethernet, WITHOUT hardware download? Plc...
3,494
i have a s7300 PLC with cp343-1 Ethernet communication processor,how can i connect wincc scada system to the plc via Ethernet, and what is the...
5,345
