S7300 Ethernet Comms
Secret
Aug 2005
Beds
55
Afternoon all,
I've been well and truley dumped in the smelly (what's new?), I've hit a wall without even starting really and am hoping one of the clever's out there can give me some pointers.
I've never used ethernet on these before so here we go.
I have a S7-313 with a CP343-1 lean and need to 'send' and 'recieve' data to a non SIMATIC PC and labeller. I have tried setting up an 'other station' on the profinet netword using NetPro (entered the IP address + subnet mask of the labeller) but don't see where it gives me the ID and LADDR values required by AG_SEND and AG_RECV. Any help greatly welcommed.
Cheers
hmm
After importing in netpro, the new devices should appear in the Hardware Config. There you can find your adresses. Did you install the GSD file ?
Afternoon all,
Cheers
You have to tell us lots more about the labeller.
You are sure that the device can communicate via Send/Receive protocol ?
When you insert a new connection, a small dialog box will appear with the connection details. There is a small picture with the ID and LADDR.
Sometimes STEP7 works erratically when it pops up a new window or dialog box. On my PC I always have to check if they have landed in the background, or behind the windows of other programs.
Hey all, I'm looking for a solution to interface a couple of S7-300's to an ethernet network so we can collect some data. We will be using...
1,495
Hey all, I’m kind of spinning my wheels a bit with this one. I need to exchange data between to S7-315 PN/DP’s . I need to send a couple of Bytes...
1,481
I have an existing system design that requires ethernet functionality. I am using a cpu315-2dp with a profibus network that covers approx 100m...
2,085
Hi I want to ask several questions. 1- Is it possible to make communication between two s7300 plc via ethernet, WITHOUT hardware download? Plc...
3,494
i have a s7300 PLC with cp343-1 Ethernet communication processor,how can i connect wincc scada system to the plc via Ethernet, and what is the...
5,347
