S7 300 Memory Card?
504bloke
Jan 2005
Down South
2,721
Hi
Just bought myself a
Siemens s7-300 cpu316-2 dp
model 6ES7 316-2AGOO-OABO
of ebay to have a play with
Do i need a memory card and if so what ones are compatible ?
For the older CPU's (like you have) you dont need a memory card.
But you will need a battery if you want to retain the program on power cycle.
I might be wrong, but, I'm pretty sure that he DOES need a memory card. There is a message thread here on plcs.net that indicates why, and also details that these memory cards are made special for Siemens, with a special code.
I just bought a NEW S7-300, and somehow forgot to buy the memory card. When the unit was powered up, I could not establish communications with it, which is how I knew I needed it (and, of course, my distributor informed me as well....)
OLD CPU's like the 316 do not need memory card. A battery would be handy unless you don't mind loading program upon power up.
Nick
The Siemens CPU 6ES7 316-2AGOO-OABO does not need a memory card, it has "built in" RAM.
From the catalogue:-
The Load memory has 192KB RAM intergrated and can accept a 4MB Flash EPROM.
Bit Memory: 2048
Retentive with/without battery = 0 to 2048
Counters: 64
Retentive with/without battery = 0 to 63
Timers: 128
Retentive with/without battery = 0 to 127
Blocks:
OB = See operation list.
FB = 256 max
FC = 256 max
DB = 511 max
See attached file for full details of CPU
Thanks for that guys
And if i want to add memory in the future presumably the MMC is the wrong type so what part numbers would i be looking for?
Will this 1Mb one work in it ? (It physically looks like its right but i dont want to blow anything up !)
6ES7 952 1AK00 0AA0
Hi Dave,
the part number matches the 400 range and i'm pretty sure it wont work.
hello Friend There is one old system with S7 300 CPU which is password protected and I dont know the password. Now I want to remove the password...
5,932
Can anyone advise please ? I did a project with an S7 315 2PN/DP a few months back and the machine has now been shipped out to China. Some mods...
5,110
Hi Group, Please correct me if Im wrong. Memory Card FEPROM serves as LOAD MEMORY that contains configuration file and user progam. Since...
5,283
I have a machine with a 315-2 DP processor. A while ago something happened (I wasn't around, offshift, etc,) and the machine stopped working...
5,704
Hi, I need to save the values entered with my panelview 300 into the PLC to avoid loss of input data when a power surge comes. I haven't got a...
6,463
