Siemens S7 300 313C Memory Card Password Reset
sarfraz_jsr04
Jun 2017
jamshedpur
hello Friend
There is one old system with S7 300 CPU which is password protected and I dont know the password.
Now I want to remove the password so what can i do now?...
CPU is not allowing me to upload / download without password.
Is there any way to reset the password of memory card without PG? an by PC - Normal Card Reader
Please guide.
Thanks for your support.
We don't discuss methods to bypass password protection on this forum. You may have a legitimate reason, but there is no way we can be sure. Your best bet is to try to locate the original programmer or the company that initially installed the machine.
You could remove the CPU from the power supply and disconnect the backup battery. That would remove the password while also deleting the program. Then you would be able to reprogram it.
Assuming this is one of the newer (last 15 years, ish) style of 300s, with an MMC:
Option A: clear the memory card with a pg or USB prommer, and start from scratch.
Option B: get new Siemens memory card, and start from scratch.
Option C: Call machine builder
You can clear the MMC with the CPU RUN-switch:
https://support.industry.siemens.co...fault-reset-or-overall-reset)-?dti=0&lc=en-WW
MMC
It is only possible to reset the MMC if it contains data* that is invalid for the CPU. (* Invalid system data is, for example, data stored for a different type of CPU.) Otherwise the MMC is only initialized by the procedure described.
All the user data is deleted when you reset the SIMATIC Micro Memory Card (MMC). Proceed as follows.
  1. The MMC is slotted in the bay of the CPU. The CPU requests an overall reset (slow blinking of the STOP LED).
  2. Set the switch to "MRES" and hold it there until the STOP LED lights continuously (approx. 9 seconds).
  3. Within the next 3 seconds, you must let the switch go and set it again to "MRES". The STOP LED now blinks during the delete procedure.
If the CPU continues to request an overall reset after the procedure described above, then the MMC is defective.
Hello all. I have an ESA HMI that is connected to a Simatic S7-300 (CPU312). I have uploaded the program from the PLC which is written with Step7...
1,450
Hello. There is a problem with Siemens S7 300. We got a replacement PLC but it does not run the program from the MMC. The new PLC is dated 2011...
690
Hi to all, Our company does not usually use Siemens PLCs, but have a press with one in it. We are trying to change the IP address in our Simatic...
1,069
G'day guys, I am setting up a s7-300 as a test rig for the workshop and when I downloaded the PLC is not going into run mode, I keep getting a...
35
5,225
I am trying to write just MSEC to S7 300 Controller date/time using OI.SIDIRECT Aveva communication driver? The old HMI (WINCC) tag is assigned...
1,059
