S7-300, MP377, Scalance S612 Time Synchronization
Hal9000
Jun 2010
London
140
Does anyone have any examples or experience in time syncronizing their S7-300 PLC and MP3xx HMI with an NTP time server?
My set-up
External Network -> S612 Scalance (with NTP configured)-> Internal Network -> X-106 Switch -> S7-300 CPU 315-2 PN/DP
-> MP 377
I would like the PLC and HMI to pick up their time/date from the NTP server that is configured in my S612.
Any help in doing this would be greatly appriciated. The simpler the better.
Cheers.
for HW config use this:
HW_Config.jpg.
You should enter the IP adress of the S612 device there.
For the HMI I know only how to syncronized with PLC(not direct from S612):
Conf_HMI.jpg,
when on db1.dbw 0 you should enter the adress when is the current time of the PLC readed with SFC1.And there should be some more bytes for system use
Regards,
Mitko
in allen bradley kinetix 300 drive first E31 error shows after resting drive E11 error occurs need solution to reset E11 fault code
165
139
309
Hi i using Kinetik 300 2097 driver control by EIP with using move absolute and incremental for motion , but i want to add same driver and motor as...
85
96
