s7 300 no comunication
forty
Mar 2007
chihuahua
Hello:
I have a problem with an s7 315 plc.and cp 343-1
I lost comunication with the system and I can"t restore it
I changed plc and cp343 also but I can comunicate and configure 'em
but only if I remove the memory card. but when I put the mmc again and try load the program I loose comunication again.
I only have comunication without MMC.
is thera any way to reset the MMC or may be it is damaged?
any help is welcome
thanks
I have once also this kind of problem. Do you have a MPI adapter. Connect with it and clear the cpu. Beware of losing data. Download your hardware and software and maybe it is fixed. Otherwise your MMC has a problem.
Hi
S7xp.com thanks for your reply.
finally the problem was the MMC, I got a newone MMC and when I installed the machine worked imediatly
thanks again
Great, problem solved. Well I searched once a few hours why sometimes my dp comms failed. Finally it was a loose cable in a dp connector.
Dear superiors, When i try to communicate Yasakawa A1000 AC Drive and simense s7-300 plc via profibus the drive shows error bb on its display...
6,922
Hi everybody , I have to wonder if it is possible to exchange data and how. Someone knows where I can find material about? any help is...
1,734
Hi everybody I have a (big) problem with Citect & my Siemens PLC. I use CitectSCADA 7.20 / Simatic 5.5 and my PLC is S7-CPU317etcetc I've...
8,073
hey , can anyone help me . I have a siemens plc s7 300 with a telesis pinstamp dot pen model tmp3000 and the controller tmc300. I have a new...
3,096
Hello Everyone. I had this problem. PLC S7 200 CPU 226 has a DB 9 RS-485 PORT and PanelView C300 has the same PORT But only 4 connector called [...
2,193
