S7-300 or other program?
arjunasakti
May 2010
dortmund
Hi everyone..
I'm relative new to PLC world. I just started to learn the program Step 7 from Siemens. So please enlighten me about my question here. I would like to know whether SIMATIC S7-300 program is suitable to run these several tasks all together:
1. to control a pneumatic gripper.
2. to run/control a conveyor-belt.
3. to control several cylinders which work as pushers/sliders.
If the answer is yes, can you guys please tell me which CPU is required to run the program.
TIA!
What you describe is a typical PLC program.
If there ís nothing else to the task than what you have described, then any CPU, even the smallest, can do the job.
S7-300 seems a little overkill for the described tasks.
If you have to use Siemens maybe you could go for the S7-1200.
Thanks for the feedbacks guys.
Btw Karsten, I'm a little lost about the programs. I'm still not too sure actually about the tasks. Most probably will need to add 2-3 more tasks to the system.
Yup I have to use Siemens S7 and my problem now is I dont know much about the differences between these program for example between S-300 or S-400 and S-1200. I just found out S-1200 is the new family to the system rite?
I opt to S-300 before just because it says it's the most used program in control system for automation.
So what I understand now S-1200 is more capable to handle the described tasks.
288
Hello All I hope you are well and safe. I have a problem that I could use your appreciated input for: SW: SIMATIC MANAGER v5.5 SP3 HW1...
1,238
Hey guys! I have a S7-300 plc and I wish to upload its program to my PG and create a backup. I have a siemens simatic pc and have set up the...
1,897
I need to utilize the program of Panelview 300 standard into Panelview 7 plus. Can anyone plzz help in this regard??
1,405
Hello everyone I'm new here and was hoping someone can help me out. I have a pneumatic punching/ bending machine that broke down running on a...
39
5,242
