S7-300 plc message 256:145
tulip
Oct 2005
ist
236
When I want to open backup program this message appare on PG.Open Project (256:145) The project or library was changed using tools of Windows Explorer.The data for access protection has been modified to such an extent that it is no longer possible to open the project or library.who has got any experience this subject?thanks in advance..
It does not look good.
I would try to locate an older backup, and do an online compare to find and update the program differences.
If there is a Protool or WinCC Flexible project integrated into the defective STEP7 project, then there is a chance to manually cut them out and reintegrate them in the new project.
there is no a protool or wincc flexible program.I did it what you say but no success.I created a new Step7 project and exit Step7 manager.I put a copy of all sub directories out of the crashed project into the new project directory.When I opened step7 project again only hardware is exist.
If you can find an older backup, then by doing the offline/online compare you can find the hopefully few differences, and update the offline project. This will keep all the comments and symbols from the older backup.
If this is not possible, then you can do a complete upload.
But the upload will not have any comments or symbols.
merry christmas and happy new year i have a click c0-00dr-d and allen bradley 2711c-t3m. can the panelview talk to the click plc via modbus...
219
Hello. There is a problem with Siemens S7 300. We got a replacement PLC but it does not run the program from the MMC. The new PLC is dated 2011...
690
Hi Any one here please helpmein simulation of s7 300 plc program with factory io. how to connect. plcsim 5 doesnot have option of s7 300 ..:
1,010
Hello, I have a bit of a situation, and I think I know the answer but this font of knowledge may prove something. I want to do the unthinkable...
2,175
hello guys, I'm trying to establish a connection between Indusoft 8.0 & simatic Plcsim but I keep getting the following error: error...
1,357
