S7-300 RTD Module value reading problemb
nilesh_1106
Dec 2011
pune
34
Hi everyone,
As I am new to S7-300. i configured S7-315-2DP with 2 input card & 1 output card..with AI8 RTD module in which 6 i/p's are used and another 2 is floating..
as I open monitor/modify values of particular PIW register...i could not read the value..my hardware connection is ok..but wheare is the problemb i did not find..
Can you post here a copy of your hdw config?
I tried simulate it on my PC, but everything works properly..!
Dear All I need a RTD input card for s7 300 ,kindly suggest a card which includes maximum inputs ... Regards
1,485
I am using the Siemens S7-300 analog input AI8x12bit SM331 to read temperature from a two wire platnium RTD (100ohm). I am pretty sure that I have...
7,989
I am trying to use the Siemens S7-300 PLC system to monitor temperature changes using a two wire 100ohm platnium RTD. I am using a SM331 AI...
13,647
20
Hi i using Kinetik 300 2097 driver control by EIP with using move absolute and incremental for motion , but i want to add same driver and motor as...
49
