Can you show a screenshot of the block and a screenshot of your tag table. The only way i could reproduce this was to set the tag type in the tag table to something other than INT.
Step7 was address based.
TIA portal is symbol based.
Orange color is only TIA portal's way to show that you are using constant addressing on code side. (warning).
On TIA portal's view you should use instead symbols names which have addresses to I/O or M-area so that code would be more easy to copy between different TIA projects.
p.s If it is actually RED color, then it is error and it won't compile.
You have to click [Upload] to actually attach something. There are only select file extensions than can be attached; if the "tag table" is not one of those types, put it into a .ZIP file and attach that.
