minerman
Hello,
I have my S7 PLC on my desk, it is the CPU only. Is it possible to get this thing to run my program without the associated IO attached? Right now it is forced into stop mode and I'm not sure why. The error info is a little confusing. Here is some of the errors that I'm getting from the module diagnostics:
Serial number: S C-C7UG46772012
Event 1 of 92: Event ID 16# 4563
STOP caused by I/O access error (OB not loaded or not possible, or no FRB)
FC number: 3
Module address: 16
Previous operating mode: RUN
Requested operating mode: STOP (internal)
Internal error, Incoming event
06:33:35.714 PM 01/02/1994
(Coding: 16# 4563 FF84 8C00 0101 0003 0010)
Event 2 of 92: Event ID 16# 2942
I/O access error, reading
P area, word access, Access address: 256
Requested OB: I/O access error OB (OB122)
OB not found, or disabled, or cannot be started in the in the current operating mode
External error, Incoming event
06:33:35.710 PM 01/02/1994
(Coding: 16# 2942 FE7A 0020 0100 0000 0000)
Edit: Also, I'm constantly having trouble accessing the module. It seems like I have to download the hardware config again and again, then I have to reset the ethernet node. I don't know if this is related to the errors or not.
FC number: 3
Module address: 16
