S7-300 Word/Bit Addressing
ASF
Jun 2012
Australia
3,921
Hi all,
In my recent travels, I came across the attached image, which has me a little confused. My understanding of Siemens word addressing is as follows:
MW100 contains all the bits from M100.0 to M101.7
MW101 contains all the bits from M101.0 to M102.7
Therefore, I should not use both MW100 and MW101 as they have an overlapping data area.
But this image says that MW0 contains M0.0 to M1.7, and MW1 contains M2.0 to M3.7
Which would mean that, from my example above:
MW100 contains M200.0 to M201.7
MW101 contains M202.0 to M203.7
So there is no overlap.
But the thing is, I've programmed with my original assumption before, and it worked. More than that, where I inadvertently had an overlap (e.g. used both MW100 and MW101), it didn't work.
Can anyone tell me which example is correct? :confused:
I'm not sure where that pretty drawing came from but it's wrong. The MW1 is a typo. Should be MW2. Also the bottom left side bits should be M3.0 to M3.7
If you really want to see it work put those MW's and MB's in a VAT and see
Write some values to them
Good. Thanks JRW.
The pretty drawing came from a powerpoint presentation titled "Top Ten Programming Mistakes by People New to Siemens". Go figure...
"[company name], a Siemens Solution Partner with the most S7 Certified Engineers in the United States, presented insights to people new to Siemens to help avoid common mistakes at the 2011 Siemens Automation Summit." (y)
Nope, it had an example before that saying "this is wrong". Then it prefaced that slide with "this is how Siemens addressing works"
It's a pity they didn't expand the example up to Byte 7. Then we could have seen from the second DW's address (MD1 or MD4) whether they were using Siemens addressing or CoDeSys and co.
Having to work with CoDeSys quite often, their addressing drives me up the wall because you can't see at a glance which Bytes (or even WORDS) are being used, whereas in Siemens it's obvious at first glamce. I've got into the habit of using an Excel Table to keep track of MB, MW and MDs in the few projects I have (mostly using V2.1) where the HMIs demand the use of the Marker area for HMI communication.
Hello, I have a bit of a situation, and I think I know the answer but this font of knowledge may prove something. I want to do the unthinkable...
2,176
How can I reading 0-65535 value reading from PIW258 address? I want to reading position parameter from Control Techniques Unidrive M600-M800...
3,205
We have a piece of used equipment we are recomissioning that I need to find a password for. The defaults that the OEM sent us are not working. I...
27
5,594
hello Friend There is one old system with S7 300 CPU which is password protected and I dont know the password. Now I want to remove the password...
5,930
Hi... Friends... I have s7-300 Plc that is password protected so I able to download n upload the programme,so please help me how to...
12,037
