S7 400 battery not work
njdujian
May 2003
jiangsu
HI,ALL
I have a problem. A S7 400 syetem, CPU 414 ,no battery ,alerm light on,install the battery, alerm disappear,but when I cut the power of CPU,the data in datablock also disappear,why???
I can't understand,help!
HI THERE
either whole program will go
or nothing
so just re check your problem
may be you have downloaded the data block because me which old data might have got disappeared
do you use the blue lithium batteries? if so smash this thing on some table a couple of times. they build up an oxyd layer that prevents enough current to flow for keeping the data. you could also shortcut it with a 100ohm resistor but smashing the battery does the job also. its a problem with this batteries since over 10 years. if you search long enough you will find some trouble information @ the siemens support on this topic
found it for you
Hi all, I have a hazardous area application for a pre-existing design that uses a Micrologix 1400. My HA panel supplier says I can't use the...
3,227
Hi, Please, is there a way to disable the low battery message in the PanelView Plus 6 400. Ser A, FTV ver 7, P/N 2711P-K4M20D8 ? Thank you
1,904
Good Morning to all Quick question. How long will the original AB battery support installed programming on a Micrologix 1400 The units were...
3,925
Hey All, Is there a Battery Low status bit in MicroLogix 1400 Series B using RSLogix500 software? Thanks,
2,518
At work, Micrologix 1400 had major fault upon resetting after power outage. Here is the info I got from RSLogix500's S2 file. "micrologix 1400...
6,025
