S7 400 communication issues
hemanth8400
May 2009
Hi every body ,
I have a S7 400 PLC .One RIO cabinet is near the PLC so we used copper cable and another RIO cabinet is far away about 800 metres so we had to use OFC cable ...I want to know whether is there any extra settings to be done in order to communcate this network ..I have an OLM (Optical to fibre optic convertor )I have set the dip switch settings also ..But it is not communicating .Have checked the cable also ...Please help me out with this
Hello hemanth;
What type of connection have you established between the CPU and the "RIO" ? Profibus-DP(You don't give any technical details in your request)? in that case, which version of the OLM are you using, and what topology are you selecting on the Dip switches?
Here you will find a link to the Profibus OLM v. 4 Operating Instructions manual, that will give you an idea of the settings required on the OLMs you are using, I hope.
http://support.automation.siemens.com/WW/view/en/24164176
Hope this helps,
Daniel Chartier
Dear all, I am commissioning an untested system of HMI: Mitsubishi GOT Simple GS2107 PLC: Micrologix 1400 B, 1766-L32BWAA Cable RS232...
4,649
Hello everyone, One of our machine we use Siemens Cpu315-2dp. And this cpu communicate with 4 Lenze servo drives series 9300 via profibus. Also...
183
Hello, iam a newbie in wincc operations. But I am a hard/soft engineer. In my father'r company, they have used a wincc based project to...
369
Hello, I'm working on a project in which I need to communicate a Micrologix 1400 series C to a Zebra printer ZD230t through Ethernet/IP. Is there...
754
Good day, everyone, We're trying to establish an S7 connection on ethernet between an S7-400 CPU and a new S7-1200 CPU (which is defined as slave...
2,640
