S7-400 CPU Replace
isteak007
May 2009
NewYork
216
I have a defective S7-400 CPU 412 (6ES7 412-2XG00-0AB0) now can i replace it
by CPU 414 (6ES7 414-2XG03-0AB0) without changing the program of the Flash Card or without changing any configuration?
According to Siemens it's possible
https://support.automation.siemens.com/WW/llisapi.dll?func=cslib.csinfo&objId=22917711&load=treecontent&lang=en&siteid=cseus&aktprim=0&objaction=csview&extranet=standard&viewreg=WW
QUESTION:
Can I replace a CPU of the S7 400 line by a CPU of the same line with higher performance without having to modify the configuration?
ANSWER:
A CPU can be replaced by one with higher performance (e. g. 412 by 414) and a CPU with n interfaces can be replaced by a CPU with more than n interfaces (e.g. 414-1 by 412-2). Please bear in mind, that the more advanced CPU has order number and release state equal or higher than the original CPU.
Thus, you can still use the existing Memory Card The HW config can remain unchanged, if the module width of the single CPUs matches.
Anyone has any experience on this issue?
According to the Siemens FAQ, yes you can do it if the firmware version is same or higher, if the number of interface ports is the same or higher, and if the CPU width is the same.
Even so, if you have the original program, the better way would be to adapt the program to reflect the new CPU.
Yes I have the original Program, But Without Siemens USB Prommer I can't change the flash card program.
I can't replace cpu S400 416-3XR05-0AB0 BY 416-3ER05-0AB0 in PCS7 Project when using replace object to keep the original configuration in the...
1,506
I need some advise as I have to replace a S5115U CPU with a S70400 CPU the catch is I have to use the existing S5 rack . Is there anybody out...
3,701
Hi All, I have a project that lets me control a Movimot drive via Profibus DP. A quick search on google learned me that a lot of information...
2,707
Dear Experts, We are currently in a project commissioning stage now of a Biomass Plant. The above mentioned CPU is used. 2 days ago, our load...
2,629
Hi, does anyone knows what is the problem on an S7-400 cpu in case all the leds are constantly on (not blinking, I think in this case it that...
7,221
