S7 400 / Op37
SHYAMAL
Aug 2007
DHAKA, BANGLADESH
53
Dear Experts,
We have an S7 400 project comprising with op7, op37, Simovert Master Drives etc. for a sanitary napkin machine. In the SIMATIC Manger while opening the folder op37 it is not opened but displays a message: " error on converting OID5==OID_POB_CTDRIVER_MANAGER. Please contact the manufacturer"
Is there anybody to help?
Regards,
SHYAMAL
Simatic Op
If so you need Protool installed on your Pc . Protool for older Siemens panels and Wincc for the newer Siemens panels.
Good luck
Siemon
52
I have a micro1400 processor running two routines (transfer compression/compression molding press). Recipe parameters are stored from job to job...
54
Is there anyone who can help me regarding this HMI is missing the choices when I make a new Device in TIA. Only 7" Display above are the choices...
83
107
Hi, Yesterday, I was at a customer site. I made one little change. Changed a dummy bool output to an actual output. I didn't add any tags, or...
344
