S7-400H Downloading problem
alijuda
Jan 2013
Iraq
62
Dear Friends
Please I face problem with Simatic PLC S7-415H , I can go online throw IP/TCP network and uploading the logic from PLC too PC but when I made some changing on the one function blocks and try to downloaded I couldn't
This station redundant works and one PLC is damged and removed from the system is that maybe effect the downloading from PC to PLC
Waiting your kindly help
The damaged pair wouldn't make a difference if it's off and/or disconnected from all networks.
One problem you may have on these CPU's is that your RAM is full. Go online, open the CPU properties, go to the Memory flap and in there you should have a button to compress memory. Press compress and see if that modifies the available RAM.
If you have a Flash card installed, doing the above and downloading will not survive a power failure or PLC reboot. For that you need to burn the card with the program, it would be something like File, Burn Flash memory or something like that.
Be aware that if you burn a new card, you cannot replace the damaged controller with its current card, you'll need to burn the new program on that card as well.
Let us know what message you get when you try to download... there is also the possibility that it's password protected, as would be expected from a redundant CPU station.
hello s7-400h and wincc are connected to each other via Ethernet. I need help on how to do time synchronization
54
Hi, I'm setting up comms at a station and I'm working with Cisco IE 3400H switches. I have been able to configure them following the Harware...
599
Hello All, For S7-400H system, can we make this redundant PLC (connected to one uplink switch) to communicate simultaneously with 3rd party HMI...
1,473
Our customer has S7-400H system for turbine control.This system communicated other different systems by CP443-1 card.Plc cycle time 6000ms.SFC108...
1,912
Hello everyone, I am lookimg for some help to figure out where come from the problem or what i can do to improve the latency. PLC: S7 416-5h...
3,027
