S7 block consistency problem
Dawen35
Jul 2015
Conwy
17
Hi All,
I have run into a problem altering some software that has been recently altered by A.N.Other. I have done my changes which are fine yet when I do a block consistency check and compile I get a warning when it tries to generate a s7-Pdiag object as it says that I do not have a suitable object package.
I have checked what I have installed and I do have the relevant package and can even open the software in s7-Pdiag so why will it not recognise it when compiling?
Any help or advise would be very much appreciated.
Regards
Dave
One thing is to make sure ALL other STEP 7 (and Protool/WinCC) applications are closed before you try a check block consistency.
Try the following to start.
Close all Siemens applications except STEP 7.
Right-click on the top of the project tree in SIMATIC Manager.
Click the "Required Software" tab, and click the Execute button towards the bottom.
My hope is that it will go through your project and check the software packages you need and the version(s) required.
I think I fixed that once before by declaring a new plc. Then copying all the blocks over the new PLC, deleting the old plc.
Thankyou for the replies, I have tried both but to no avail. I have spoken to one of our senior Engineers today who thinks it maybe because there are two types of Pdiag, a standard and advanced, and that we may have the wrong one on the PG. He is going to look into it for me but as it is only showing up as a warning I can proceed with the work required.
Thank you for all your help
I made a project in S7-300 plc.There is a choice in a menu;check block consistency.What for is using this?Please look the attached file and what...
1,845
In the past, we have used AB 1492 feed thru screw terminals a lot. Lead time on these with our distributor is terrible. Is there an almost...
121
Hello, This product that I have the 1790D-T8BV8B is discontinued, does anyone have the EDS file for it? I wonder if TechConnect will have this...
188
Hi, I have attached herewith one image which our programmer has been used in S7 1500 PLC. Now we need to use the same instructions in S7 1200 PLC...
120
Please see attached file. I need this program in Function Block form but I am totally lost on this. Any help would be appreciated. Thanks!
301
