S7 change FC/FB addresses
jatz76
May 2009
Gold Coast
We have a S7 (v5.5+sp2) program in which we want to change the address of certain FB's and FC's without the code loosing the addressing. Note: we are using symbolic programming, PLC is a 317.
I was sure that this was done by changing the PLC's "Address priority" to "Recommended for symbolic programming" and "For all accesses (I, Q, M, T, C and DB)".
I believe this should then allow you to change the address in the symbol table and the object's address to the new address, do a consistency check and all should be good! (this article is similar)
This however does not seem to work. After the changes, opening any object that has a reference to the original FC/FB address still has the same reference not the new one. It's like its not using symbolic referencing.
Have I miss understood this or am I doing something wrong? I'm sure I did it this way a while ago!
Maybe you could try to convert your programs to a source file, change the assignments in the symbols file (don't forget the instance-DB/FB-assignments), and compile. You must probably delete all blocks first, or compile to an empty blocks folder.
Kalle
Kalle
Thanks Kalle. This did work for me and I should have thought about it myself! I then tried the Rewire option and that works even better in my situation.
Use the re-wire facility. Right click on the blocks folder.
Thanks L D[AR2,P#0.0]. This did the trick. I've spent the last few years re-wiring my brain to use S7 coming from Schneider and Rockwell plc background. What a journey. Still find some things frustrating but this one helps heaps.
So I have a panelview plus 600 hooked to a L33er plc. Plc is 192.168.10.2 and the panelview is 192.168.10.3. I would like to be able to change the...
1,185
Good Morning , I have a CompactLogix L18 on my desk that I would like to mimic other CompactLogix L18's thruout the plant to , try concepts...
3,800
This is one of those 'Doctor, it hurts when I do this' issues, where the solution is 'don't do that !', but it concerned me enough I wanted to...
5,266
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
138
Hoping someone can give me some guidance or confirmation of what I need to do. We have a FactoryTalk SE program that I need to change the IP...
98
