S7 Common ODT in multi instance FB
Longhorn
Jul 2008
Scotland
250
i am having problems figuring out whats going on here. i have an FB which i called FB100, inside this i am comparing an integer value to a setpoint and triggering an alarm condition if its outwith the range. when the value is outwith the range i run a odt timer for 1 minute before issueing the alarm.
i am passing the s5t#1minute into FB100 from a parameter DB.
FB100 is used in 6 seperate instances....
The problem im having is when i simulate this using plcsim the timer elapses instantly and the alarm bit is set.
When i check online, the s5t#1m value is being passed into FB100. am i trying to do something which is not allowed??
im puzzled ????📚
Version 5.3 SP1, i hope you are correct as i have been modifying my code but no matter what type of timer i use even SFB4, its still just times out instantly.
I have WinLC SoftPLC so i can test using that..
Thanks LD
Good Afternoon , I'm sure there are many Ishida Muti-Head Weigh Systems . We have a Ishida CCW-M-214W Multi-Head system . We are...
580
Hi, I am connecting an Autonics make stepper driver type, MD5-ND14 to a Kinco PLC (K205 series) this has a sourcing output which cannot be...
1,130
I speculate that PLCs translate the language from programmers (e.g Ladder Logic, SFCs, Structured Text) into a common intermediate language...
4,267
Good Afternoon , I have a Powerflex 70 Drive . It faulted out with a #12 HW OverCurrent Fault . With your experience , what is the...
7,905
So I ran into something today that surprised and confused me. While troubleshooting a DC circuit I normally put one lead on a ground and probe...
1,658
