S7 different code/data assignment offline/online.
JesperMP
Feb 2003
ᚴᚬᛒᛅᚾᚼᚬᚠᚾ
16,342
Greetings PLC afficionados.
Someone tell me why there is such a difference between what memory requirement is reported between:
STEP7 offline: "Size in work memory" code 27kB data 3kB
STEP7 online: "module information - Work memory" code 56kB data 12 kB.
:unsure:
I have used "compress" - made no difference.
PLC is S7 412-2DP.
Of course I would like to have as much memory available as possible, so the actual online info is a bit disapointing :(
Replying to my own post (sad, isn't it):
The actual (online) memory assignment also contains the hardware config, communication jobs, retentive merker memory etc.
There is a button when viewing "module information": "Details memory area" that will provide just that.
Then I'm only a little mad at STEP7 for not providing an offline information about the total memory requirement for the application (maybe there is somewhere, but where ?).
There is-
Right click on blocks (from the Simatic Manager)
Object Properties-> Blocks Tab
Bingo
There's your work memory and load memory size
JRW,
what you write is what I thought too, but doing so will NOT tell you the actual TOTAL memory requirement ! Only for the blocks. Try yourself to compare what OFFLINE Blocks .. Properties says and what ONLINE module information says.
RolfB,
thanks, but that program will only make a rough estimate of how big a CPU you should choose.
I have just had it confirmed from Siemens hotline, that STEP7 OFFLINE does not inform the total memory requirement - only the memory requirement for the code and data blocks that you have defined yourself.
Started receiving this error on some of the C-More HMIs that are part of the plant network. There does not seem to be any issues with...
2,361
Hello there! I've got one little problem with S5-135U program that's driving me crazy. I've got those two segments: It's a classic positive...
1,339
I have a process recipe with 8 steps, each of which I have defined in ST. The user should be able to however, select the order in which these 8...
1,639
Does anybody have run into the issue when the same structured text code from a subroutine has hiccups while copied/pasted an AOI? The issue is...
6,267
Hello all! So I have one project with a S7-1214 and a MTP1500 "Project1" and one project with another S7-1214 "Project2". Both of these PLC:s need...
88
