S7 FC633 Converter I->T
John Parker
Mar 2009
Jackson, TN
I am trying to use an FC633 i->t converter and it keeps giving me an error on my unit type and was wondering if someone could look at it. No matter what I put in for the unit 0,1,2,3 or ms,s,m,h it says it is invalid.
The screen shots of the ladder and db are attached
Where has FC633 come from ?
If you hover your mouse over the word UNIT the data type expected will be shown to you
FC633 is in a library siemens provided us. Help for it shows up as FC233. When I hold the mouse over the word unit it shows 0=ms 1=s 2=m 3=h. But if i put in 0,1,2, or 3 it says invalid and i tried putting it 0=ms etc. and it says it is invalid. Thanks
Here's a screen shot showing the hint text when I hover over the text I in the call to FC5 - can you post a screen shot of what you get ?
....or click on the entry field for UNIT and read the text that appears in the bottom pane
Okay got it. Thanks for your help. I had added the fc prior to adding the data into the db, had both open at the same time. Closed both opened the ladder by it self deleted the fc, put it back now it works.
I am looking for a fiber-to-copper media converter that is 120 VAC powered with terminals for placement in a small panel, so I can't use the wall...
143
Problem: Our PLC can only output 4-20mA, but the actuators it needs to control, modulate based on a 0-135Ohm signal. Buying 4 or 8 individual...
285
I would like to install a non HART device in a system that uses HART, do you have a converter
105
Communication between devices will stop working for a certain period of time. I caught the error message using WireShark. I cannot identify the...
111
Hi all, I'm having a Red Lion DSPLE000 protocol converter on site to interface comms between an Allen Bradley L36ER CompactLogix, a S7-300 PLC...
524
